My Aquatronic +1 7.5kw electric shower has been giving cold water. It doesnt give hot water. So I replaced it for a like to like Aquatronic +1 7.5kw shower, the same problem still exists.
I was told to check that the shower is getting 240v, it was getting between 230-240 nothing less and nothing above and I was told this is perfectly fine.
I was told the new shower is faulty, so I got it replaced AGAIN for the same model and the same problem persists. The water pressure is fine (not thast I have checked it) but it has a strong pressure on the cold setting. The existed there for a long time and suddenly its become spooky.
One thing I have noticed is that, if I turn the shower off from the pull cord, and put it on a hot setting and turn it on from the pull cord it gives hot water but if I change the temperature it goes cold and it wont go hot again.
Also the pull cord has a red led which is blinking. Could this be the issue? Or do you guys think the old shower packed up, and the current batch by Aquatronic is faulty?!
Any help appreciated, cheers.
