Architrave
3 Oct 2006
Wolverhampton
Hi
I've had an extension built and have started fitting the skirting and architrave. All the walls and ceilings have been plastered and the floors tiled.
However I have found that neither the floor, the ceiling or the top of the dooways run parallel with each other. So I was wondering what line do I use for the architrave at the top of the doorway ?
Thanks in advance.
heeelllooo stevenbr and welcome :D:D:D
archatrave follows the door which follows the frame :wink:
set the archatrave back 6mm from the front edge
draw a light pencil line 6mm from the front edge all round the frame
this is a touch on the large side but allows for a bit off tinkering just in case :roll:
