Are all grp flat roof manufacturers the same?
If the fall on the roof is not correct what would be the simplest way to achieve this?
I understand i could use firring strips, are there any other options?
I've laid down the new osb3 board but its shy of 2 inches short to the right side which means its not flush to the top of the fascia board.
The existing roof was plywood which I've removed
Other than cutting a 2 inch strip from the plywood, is there any other option?
What would would be the best way to tie the 2 inch plywood to the osb3?
