Three years ago we had our conventional boiler replaced with a condensing boiler. The conventional boiler was in the garage, to which two water pipes used to run. These pipes were cut off and capped, but protrude into the void above the garage door.
We are now getting quotes for a roller shutter door for the garage, and the pipes are intruding into the space required for the door coil.
Our installers have said they can cut the pipes back, but they have raised the question as to whether the pipes are "live" or not.
There is one redundant pipe visible in the floor of the airing cupboard where the combi is installed (where the hot tank/pump/diverter valve used to be), which I'm guessing is the other end of one of the pipes in the garage, but is it likely the other pipe in the garage is still connected to something?
