Hi again folks.
Need some advice as I thought I had settled on a boiler (a WB Combi), but now a couple of spanners have been thrown into the works, so to speak.
Two of my wife's friends have just been to visit and both of them, separately I might add, have told us that combi boilers are problematic regarding the flow rate of hot water.
Now, I PRESUME that this is due to their particular boilers being (a) a few years old and not as "good" as modern state-of-the-art boilers and (b) probably more likely(?), underspecified.
They claim that when running a bath, for example, it is OK if you trickle the water in, but if you "turn the taps on full", then you quickly start running lukewarm or even cold water. Is this the case or is one (or both) of my assumptions above, the case?
For a decent flow rate for a bath, what sort of figure am I looking at?
What sort of capacity is a bath for a decent soak - 100L / 150L ??
Will I get the same hot water flow rate as the mains flow rate (presuming the boiler is sufficiently specified)?
Combi boilers are supposed to be slightly more efficient than regular or system boilers - correct? Is this because the stored hot water in the hot water tank is slowly losing heat during the times when hot water is not required - and a combi simply heats the water "on demand"?
Finally, when we have a prolonged "cold-snap" like we did recently, presumably the incoming cold water from the mains will be slightly lower in temperature - and therefore a combi will heat the water to a slightly lower temperature (the differential temperature will remain the same)?
Thanks in anticipation.
Dave
Dave
