Are Heat Shields a MUST?
2 Mar 2007
Gwent
I have a Citroen Saxo 1.1 P Reg.
There was alot of noise coming from the exhaust.
I took it to a garage and found that the problem was the heat shield was loose and was knocking against the exhaust.
The mechanic solved the problem by removing it altogether, when I asked if I needed it, he said no.
Is this right, surly it's there for a good reason.
Do I need to replace it?
Thanks in advance.
If it was removed from underneath the catalytic convertor i would replace it because they become extremely hot and if you park over combustable material i.e grass, waste paper the inevitable will happen.
As I understand it, the shield is there to protect the cat as much as anything else. Some cars (most in fact) don't have a shield on the cat so I wouldn't worry too mush.
mistertoyou said:
thanks for the replys.
so all in all it's ok to drive, but get it replaced asap?
I wouldn't bother mate.
I've had a few cars with noisey heat shields and i've taken them off without any problems.
Just to be sure, have a look under the car and make sure there is nothing close to the exhaust that's being affected by the heat
