- Joined
- 15 Jan 2025
- Messages
- 187
- Reaction score
- 5
- Country
Hi all, i'm planning on fitting some grab bars in my bathroom, around the shower and toilet. That is, fixed handles designed to be strong enough to bear the weight of a person, so they can pull themselves up.
This is a Safety thing, people could get hurt if they aren't properly fixed. I have a fair bit of experience with masonry drilling by now though, i'm not too worried about that, though I would appreciate advice for this particular application. I have screw and plug pairs in 6x60, 8x80, and 12x120mm sizes, i'm pondering which and how many to use to fix a bar that can support a human pulling on it
I know that screws fixed into masonry are at their strongest when dealing with shearing forces, that is, parallel to the angle of the wall they're fixed into. And consequently, they are at their weakest in a pull-out force scenario, with force being applied along the direction of the screw to pull it out of the wall. I've got quite a few shelves that could probably bear my weight if i stepped on them, but they might come out of the wall if i grab and pull
Knowing that, and given that grab bars are -designed- to be pulled on, another thought came to mind. Shouldn't it be possible to install multiple screws at an angle splaying out from each other, to fix one object? The thread of each screw tilted outwards from the object along angled drill shafts
So that there is no angle you can pull it at, which exerts force along every screw. Doing it to any one screw would have others be sheared and should anchor better
This would presumably require much longer screws than otherwise, and deeper drilling, and maybe be tricky to drill, but i can't see problems with it aside from that.
Is this a thing that is commonly done? Does it actually provide stronger fixings like I imagine? Are there problems i'm not forseeing?
