Are there any consumer units that have 3 bus bars?
My shed 'backs' on to the wall where the CU is (with a gap of about 1.5m), so I had in mind to go straight out the back of the CU with T+E, then transition to SWA in a conduit box (http://www.tlc-direct.co.uk/Images/Products/size_3/CO20BX1.JPG), go down the wall, under the patio (can lift slabs and make a trench), then in through the bottom of the shed.
If any of the T+E is 'buried' less than 50mm deep in a wall, then it theoretically needs RCD (or RCBO) protection - it sounds as if that might be a 'debatable' issue in your case.
If SWA could bend 90 degrees could do away with the transition from T+E altogether! ... Can a CU take SWA directly or would you need to transition back to T+E.
Although some people do it, IMO attempting to gland SWA into a (usually 'flimsy') plastic CU is not really a very good idea. Opinions may vary. Bernard may pop up with a picture of one way it can be done!
PS: Not doing any of this myself (well I may route the SWA).
You will need to agree the SWA routing with your electrician, who may then wish to supervise/inspect its installation, if you will be expecting him/her to be able to sign the relevant certificates.
Kind Regards, John
Of course. I meant to say that I'd do it while he/she was there doing the other bits!
