My sister is renting a flat and has lived there for a week. It has had a few problems but the landlords have sorted the issues out. When I first visited the premises I noticed an old 4 way Wylex standard unit with a maximum capacity of 60A through the switch. I thought it was dodgy because it has a circuit braker and three fuses. The circuit braker is 40amp, another fuse is 30amps and the two light circuits are 5 amps. So the fuses can handle more current than the main switch on the unit can - surely that is not legal? I suspect age of the fittings it is a late 13th edition install, I would say circa 1978-1983 and the other fittings in the flat (such as kitchen and door handles) date to the same era.
Anyway on day two my sister noticed a light switch was getting hot, this is something I could fix in seconds at home, I suspected it was just a loose wire causing it to arch and the sparky came round today and confirmed there was a loose wire behind the switch.
However he was deeply concerned that the flat still had a fuse box and it had no RCD etc. He went off on one saying it was not to regulations and it needs changing instantly.
Now our house has a similar Wylex unit, but 6 way, again no RCD protection. In a private home it is perfectly legal and deemed safe, so why was the spark so quick to condemn this poor old Wylex unit?
Do traditional Wylex style fuse boxes now mean an automatic electrical safety inspection fail?
He has also demanded that the bathroom light fitting is replaced, because it is just standard lamp holder with no water proof protection, again if this was legal in 13th edition wires does it automatically fail an inspection?
So my question is, if you're renting out a property do the electrics have to meet newer standards than in a private property?
