Hi all - After a drain down (due to having new rads etc), my combi boiler will not re-pressurise again. Water is filling the system back up but not enough to move the pressure gauge. I have changed the one way valve on the filling loop, and checked main water pressure, which is fine. It re-filled fine yesterday but now won't.
A bit of history, the house had all new rads fitted 6 months ago, was tested, then drained down about a day or 2 later, and was left like this until yesterday. I went to fill the system up and it was fine, spotted a leak on a rad valve so drained down, fixed leak, now I've got the above problem...
No leaks anywhere and pressure release valve is fine.
Any ideas
Colin
Any ideas
Colin
