I have an ageing Ariston A23/MFFI that I can't really afford to keep alive, much less to replace. It has developed multiple faults over the course of 2-3 years that I've mostly learned to live with:
1) First the diverter valve diaphragm went. None of 6 plumbers I called would replace it, with two offering to replace the whole valve at a cost of a few hundred pounds and the rest preferring to replace the whole boiler, all for a £5 part. So I did nothing and lived with turning the heating on to get hot water.
2) Then the air pressure switch started to play up, so no heating or hot water without a vigorous thump on the top left of the boiler. More annoying, this one, but I've lived with it for a year or so figuring it reduces the gas bill.
I did try the local Ariston service centre, who also quoted me some fairly obscene prices, so again I did nothing. Now, tonight, it's put the wind up me; wouldn't fire up at all and no amount of thumping fixed it. Much cursing later, I had the front off the combustion chamber and blew into the pipes connected to the air pressure switch - which has fixed the problem at least temporarily and confirmed the air pressure switch as the suspect. So, now what, I ask myself? I'm a reasonable DIYer, but I'm no heating engineer and will have to RTFM to drain down and recommission the heating system. But, I'm not minded to pay somebody £300 to fit £25 in parts. So a few questions:
1) The air pressure switch looks like I can easily swap it out myself; does this sound like a reasonable thing to do and at what point should I decide that there is a need? Do they routinely live a while after such treatment, or is this a part on its way out?
2) I am a lot less confident about the diverter valve, but, I am tempted to learn. Am I likely to **** everything up if I calmly and methodically drain down the heating system, isolate the boiler, remove the valve and replace it with a new one? Since they sell the diaphragm separately, should I consider replacing it or are the locals right in saying replace the whole valve?
3) Does anyone have any comments on the lifespan of these boilers? I *really* cannot afford to replace the boiler right now and am very tempted to throw far smaller amounts of money (and larger amounts of time and hassle) at keeping this one alive. However, it must be ten years old at least, and I'm not sure how long I should pursue that policy before just finding some way to replace the bloody thing. Thoughts?
Thanks in advance for any advice / opinions...
