Ariston micro genus combi boiler
7 Jan 2008
Staffordshire
Hello there, daughter just moved to flat, when tried to start up boiler, it ignited ok then light came up showing A77. I believe this means water in condense trap. This was emptied and worked fine for a little while but after it was switched off and tried again the same fault appeared. Does anyone have advice re the above. Thanks
this is a faulty recouperator and small pcb the one you have on the boiler will have a mauve wire on the recouperator this has been updated and moved to a new postion and the new one is a black wire the small pcb is changed at the same time.good luck
