All,
Many thanks for your help on all of this stuff. Very much appreciated!
I however now have another problem. My Ariston WRC-NSF tank is not heating water properly (the overflow leak issue was sorted out by Homeserve, and turned out to be the T&P valve).
When I switch the top immersion heater on, I get hot water as expected. When I however switch the bottom immersion heater on (off-peak, main usage heater), the water is only mildly warm.
As I still haven't moved in (but hopefully next weekend ), I'm not quite sure whether the bottom immersion heater was heating water to the correct temperature or not.
Having had a look online, I see that there is a reset buttom on each of the thermostats for the heaters, as well as a screw to adjust the temperature.
I'm thinking to have a go at adjusting the thermostat, but what is the best way to find out what temperature it is heating the water to?
Many thanks in advance!
P
P
