Armitage shanks 'sandringham' toilet can tell from my previous post on here it is almost exactly 3 yrs old ...
Close coupled, push button, bottom fill
Suddenly started constantly filling and overflowing into pan. Not a drip it like a tap running - the flow from the inlet isn't slowing down at all...
Figure its a problem with the water inlet valve??
Realised have no idea how these work
(did have an idea of the good old fashioned ball cock)
Thinking the plastic box thing around the valve is a float - and that being at the top doesn't seem to effect the flow rate
...seen mention of a diaphragm - could this be causing this?
Can that be repaired without removing the whole inlet valve?
Anything else I can do - short of replacement of whole valve -which if I have to mess around taking off the the whole inlet valve off anyway I might well consider ...
Just had a chaotic week - then this started! As I was on my way out the door this evening to a school event (last thing I had to get through - only got back 45 min ago)! And I was so looking forward to a restful weekend!
