I'd say get the heaviest grade you can and cut it as tightly as you can to prevent sideways movement and leave it at that, i'd be inclined not to glue it down for any future maintance that may need doing.
Should of asked first but is this a balcony large enough to allow you to walk on?
Yes the balcony is big enough to walk on. 6.5m x 2m approx.
Quite windy so if you suggest no glue then may also weigh it down with some chunky plant pots or wooden blocks
