    Dismiss Notice
Assembling basin and toilet
Discussion in 'Plumbing and Central Heating' started by Richhen, 30 Oct 2020.
  1. Richhen
    Richhen
    19 Mar 2016
    70
    Thanks Received:
    Country:
    Hi folks,
    Quick one.....
    When assembling waste for new sink and seals for toilet cistern, is it usual practice to smear some leak sealer eg fernox LS-X around the seals before fitting or does that cause more problems than solutions?
    Also threads for cistern inlet - good practice to wrap in ptfe tape?
    Cheers R
  2. terryplumb
    terryplumb
    8 May 2017
    5,189
    Thanks Received:
    1,057
    Country:
    Float valve ( cistern inlet) doesn't need PTFE . Just the seal.
    No sealing compound on any other toilet seal.
    Waste fittings on basins vary ,different designs available. Silicone sealant applied to the underside of the waste fitting where sits against the basin ( topside) is required ( or plumbers mait putty if you prefer).
    On the underside of the basin there will be a seal and it is usually all that's required to make watertight.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. Richhen
    Richhen
    19 Mar 2016
    70
    Thanks Received:
    Country:
    Great thanks @terryplumb! Makes sense, just wanted to be sure.
  5. Madrab
    Madrab
    4 Oct 2012
    7,353
    Thanks Received:
    2,021
    East Renfrewshire
    Country:
    Have to say that if your fitting the metal waste into the basin then the seals supplied aren't usually up to the job.
    The fine washer they supply for the top is normally ok but I'd then use a basin mate or a little silicone to seal the gap around the shank of the metal waste and basin waste hole underneath before fitting the rubber seal and large nut, so it seals properly.
  6. Sponsored Links
Loading...
Share This Page
