Hello.
I have an ATG MX48 (I believe that it is the same as a scantronic 9100).
Lately, I find that when I set the alarm and go out the final exit, the alarm will sound after the front door is fully closed and secure, forcing me to go back in to turn it off. I then repeat the same process of entering the code and leaving, and the alarm doesn't go off.
The pattern is 1) I enter the code and the alarm starts beeping. 2) I exit the front door while the alarm continues to beep 3) I close and lock the front door, while the beeping continues. 4) The alarm beeps for a while more, and then sounds.
It is as if the alarm is being tripped even though there is no motion on the door or any of the motion sensors.
It seems to be worse for my wife, who probably closes the door with a little less force than I do.
Is this a problem with the reed switch and magnet, or is something else likely to be going on?
