I am in the middle of a pc rebuild using an Asus main board and an Athlon 64. The CPU came with it's own amd fan. The problem is that try as I might I cannot get the plastic locking arm on the heat sink to go down. I can get the metal bracket to lock over the retaining lugs which seems to secure the heat sink perfectly well but the arm just will not go over. I'm at the point where something will break if I push any harder
I have had the fan and heat sink off and it's clearly been on the processor properly and the processor is in its socket properly, it just seems to be a faulty locking arm
I have put it back on with new thermal grease and it seems to be firmly locked down again. Given that the bracket seems to be locking it ok does any one here have any views on what I should do. My instinct is to ignore it, leave the locking arm up and just carry on but i'm worried i'm missing something obvious or doing something daft. This is the 3rd machine i've built with this design and I've never had this problem before
Any help gratefully received
