Attached pergola on patio
17 Jul 2017
I am hoping to build an attached pergola which will sit on a paved patio.
I've tried my best to sketch some very rough drawings of what I am looking to do. Although it is rough the scale is reasonably accurate. The pergola would be 6.5 metres long and 4 metres wide, with the wall plates at around 2.4 metres.
I am currently planning to use 90mm square posts with the rest of the timber, including the wall plates, being 145mm x 45mm, all pressure treated.
I would have preferred to use thicker posts (ideally 150mm) but 90 is the best I can find at short notice (I can get 100mm rough surface posts, but by the time I have planed the surfaces there won't be much difference).
These are the posts - https://www.diy.com/departments/premium-square-pergola-beam-h-3000mm-w-90mm/5022652848408_BQ.prd
And this is the other timber - https://www.diy.com/departments/rou...k-timber-l-4-8m-w-145mm-t-45mm/1798322_BQ.prd
Not my preferred source of timber, but again I am limited with what I can get quickly.
The patio pavers are 600mm x 600mm x 50mm and I am hoping to bolt the posts directly to the pavers using one of the various post shoes, rather than having to create a concrete base.
I will add a lightweight system to block the sun for now, but I also plan to pitch the top, to give the option to add some kind of simple watertight roof later.
I'd like to get peoples thoughts on whether the materials specified and the post fixing method would be suitable.
Any input would be much appreciated.
Some of those B&Q timbers that you linked are untreated indoor timer and It will rot.
Better to have treated timber, eg:
https://www.travisperkins.co.uk/pro...terials/sawn-timber/treated-timber/c/1500002/
or
https://www.wickes.co.uk/Products/Building-Materials/Timber/Treated-Sawn-Timber/c/1000202
Thanks. Near the bottom of the page it does say in the "features and benefits" that it is
"Treated to help prolong the timber's life and protect against rot or insect attack"
But, if it isn't appropriate, I will switch it out with this, which I can get easily.
https://www.bradfords.co.uk/treated-sawn-timber-47mm-x-150mm-ttl134
Wickes is my usual go to, but I couldn't find long enough pieces for the rafters.
Mine is half the size of yours but similar in being lean-to
I used treated timber from a landscape/fencing contractor.
I only have 2 posts, but they are buried in the ground with postcrete
