- Joined
- 3 Jan 2026
- Messages
- 13
- Reaction score
- 1
- Country
I'm currently working on our bathroom and need to batten out a theramlite block wall. This is to level out the wall and also provide space for the plumber to run some hot and cold feeds for a wall mounted tap. The wall will eventually be backerboarded and then tiled.
I plan to attach the 25mm x 50mm battens to the wall using 65mm fischer duopower plugs. As this wall will be tiled, I just wanted to double check that this approach is suitable.
Thanks all.
Thanks all.
