Hoping to insulate single block wall between integral garage and utility room to be used as study.
Plan to screw battens to wall to create small cavity and then attach 50 mm foil backed kingspan insulation board. Finish up with plaster board screwed or nailed through board to the batten. Alternative is to use foam backed plasterboard attached to battens mechanically.
Is there a suitable adhesive to attach foil backed board to narrow battens instead of nailing or screws?
