Was the water warm?
Andy
Andy
Was the water warm?
Andy
Irrespective of what`s knackered you need a new Part 2 Half inch float valve and float in place of that old one - the overflow pipe is too high through the cistern wall and you could get thatwater drawn back into the mains , Also a part 2 is much easier to adjust the water level
Is the level of the water in your big tank higher than the small tank? :
Both tanks sit level on the same boarding, but as the cold water tank is much bigger, the water is higher in the cold water tank.
Yep..........new cylinder needed!
