Audi 80.
23 Sep 2006
Kent
Will a head from a 1990 Audi 80 2.0 8v fit onto my 1993 Audi 80 2.0 8v??
The reason i ask is, the valve stem oil seals have gone on my '93 Audi 80 and i have just purchased a head which has been pressure tested, skimmed, had valves ground in and new stem seals fitted and i got hold of it real cheap. If it does fit then its a question of one head off and the other on, my time is very limited.
Phil.
It should do. Quite a few options listed but i think it's different cams, but the casting itself is the same.
Post up the part numbers for both and i'll check for you. Unless they're the same then obviously it will fit!
Either that or have a look at www.vagcat.com , you need to register but it's free and as far as i can tell don't get any spam or anything from it
Thanks for swift reply Neo and good mornin' to ya 8) Cant get numbers yet as my new head dont arrive till Mon/Tue.
