- Joined
- 1 Sep 2018
- Messages
- 445
- Reaction score
- 71
- Country
The mother-in-law has an issue with her Audi A3, it is a 2.0 tdi, BKD, 2006 MY engine same as MK5 Golf and it displayed a warning for low battery on the graphic display along with ABS/Traction control/Steering warning/engine management lights on the dash.
I checked charging at the battery, 14.2 volts, I also checked the battery condition sight glass and it shows a green ball.
I check both sides of the maxi-fuses in the under bonnet fuse box, again 14.2 volts and the "buzz bar" with the strip fuses mounted on the front of the under bonnet fuse box, all 14.2 volts and all measured both sides of the fuse.
I am currently unable to find my VCDS lead but I suspect it will show a bunch of ABS/steering faults.
Could anybody suggest any common problems given that the car starts and drives normally apart from the warnings? Obviously I need to rectify before the MOT.
