AVC 35 tc or Gledhill Gulfstream A class
14 Aug 2006
Berkshire
I have a 4 bed house with 2 bath, the pevious owner had a combi fitted, located in the garage (left of garage door) with the flue facing the front of the property.
I want to upgrade the system to improve flow rate without messing up too much with the existing pipework.
I am looking at the AVC Heatmaster 35TC and GledHill Gulfstream A class
as the easiest replacement option to replace my existing combi.
Have not seen any reviews of owners of these units and if there are any problems with them. Which of the two would are more reliable, Is there a better option to go for.
Best Regards
Kolassery
Best Regards
Kolassery
Go for the ACV Heatmaster, a quality product. At about £2,300 it is well priced too. Stainless steel throughout. Cost a system boiler, the controls and the cylinders/heat bank to do two baths and it will cost more. The ACV is neat and all in one box saving space. It condenses all the time.
Before you fit the ACV, put Fernox DS40 in the system to clean it out. A clean system is vital. On the CH return to the ACV install a Magnaclean filter as well. Make sure the mains is up to it, and have a dedicated 22mm cold supply to the unit with no tee offs - also a full bore maintap too. You will not be disappointed.
