Hi there hope someone can help me. I am replacing an old aqualisa shower unit, with a new Axor Uno unit. The old one was gravity fed, and the new one is in exactly the same position, although there are now several extra elbows and fittings. The pressure on the old one was fine, but having fitted the Axor, the pressure is pretty dire. The cold and hot feeds are both in 22mm, and the exit to shower flexi is in 15mm. Is it the elbows that are reducing the pressure, or should i run the exit pipe in 22mm and then reduce to 15 just before the flexi.
Hope this makes sense to someone, any help much appreciated.
