[b]help saniflo driving me mad[/b]
reverse flow valve might be leaking, allowing water back in?
Does it go of continuously or is it on/off/on/off etc?
just continuas running
a week ago it stopped if you gave it a gentel kick now it just runns all the time untill fuse is pulled out
many thanks,
so if i take it apart and clean out the pump chamber and check the return valve i should get somewhere (apart from very messy)
will try this when i get home
many thanks
yes just becareful to isolate the power when working on it as the blade will take your hand off.
