b&q kitchen on uneven floor
9 Jun 2009
Yorkshire
hi i have bought a b&q kitchen and have built the units up and used one of them lasers on a tripod to mark out base units and theres about 25mm difference from one end to the other so my question is do i start at the lowest point or the heighest???? id have thought the heighest but there would be a 25mm gap above the endpanel :? am i doing somthing wrong ?? hopefully somone can enlighten me
thanks
Rich
25mm out over what distance? Don't know what type/age of property but it's an awful lot for the floor to be out even in a large room, are you sure you levelled the laser tripod correctly? Have you tried checking the accuracy of the “on board” bubble level with a spirit level?
Id level the floor first if its possible. if its not then ull have to work from the lowest point and cut the bottom of the end panels and the bottom of the plinths
trouble is the plynths are 150mm and if i reduce the legs down to min its 150mm so i would need to cut the legs down too
its an old terraced house early 1900`s
the floor is out 25mm over 3100mm
and yes i levelled laser correctly and double checked by marking wall and checked with spirit level
another idea would be to start from heighest point and when i get to lowest point take back my short end pannels and get the long ones and cut to size, i could also cut a long end pannel down for the plynths if required
your thoughts on this would be apprechiated
Rich.
it will cost you a fortune if you cut down end panels to use as plinths bear in mind you can have a bit of a gap at the top of the plinths because your not going to see it unless you get down on your hands and knees and look under the units
good point tommy but 25mm is a bit much and i wont be using end pannels only for plynths just the last 1.5 meters where the gap will be too bad.
i can get a pack of 2 x 1800mm x 570mm for about £45 which isnt that bad especially when i take the short ones back
this is the best solution i can come up with
if anyone can come up with a better one im all ears
Whatever you do,,, make sure if you have any under worktop appliances (washing machine/fridge etc ),, leave a minimum height of 870mm where they are going. otherwise they won't fit under.
god how gutted would you be if you fitted a kitchen for a customer and then when you put all the appliances in place none if them would fit! Itd definetley be a heart sinking feeling its got to have happened to a few people in the past
