I have a fire with a back boiler which I use a lot I used to have a rad in most of the rooms as well as having gas centra heating rads in every room, because I didn't want two rads in every room I took out the ones that fed from the back boiler, now whenever I lite the fire the water boils because no rads is feeding off the boiler, I wonder if it would be ok for me to put two valves in so that I can change the rads so that they either run from the gas or the back boiler, this would be quite easy to do as the pipes run side by side in the loft.
