- Joined
- 30 Jan 2012
- Messages
- 29
- Reaction score
- 1
- Country
I've fitted a new downstairs radiator and both it and the downstairs rad I've "spurred" it off refuse to get hot. I'm confident the pipes are connected correctly, and the new rad is fitted with a bidirectional TRV. All other rads and hot water work fine, so it seems highly likely I've got an air lock. It's a standard vented system with a fill and expansion tank.
Trying to clear the air lock in the usual way by turning off all other rads doesn't work.
I think I may need to back fill using a hose pipe (acknowledging care needed to ensure adequate F&E overflow arrangements). Unfortunately I didn't fit a lockshield valve with an integral drain cock to the new rad.
My question is this: to save me draining everything down again, is there any easy way to connect a hosepipe to the air locked rad via the radiator plug aperture?
Thanks in advance for any advice offered. Sorry if this has already been answered, but I did do a fairly thorough search.
