Moved into the house in 2005 but this window change was ordered by previous owner in 2000. They had a patio door removed and bricked up the lower 800mm across the 1850mm wide opening topped with UPVC window above that.
In 2007 I found that there was a 40mm gap above the header with no fixings or foam, just plastic trim over the top. I filled the gap with expanding foam to glue it to the concrete lintel and kill the sound leaking through. I chiselled out the mouldy bottom corners and replastered the reveal thinking it was a condensation issue from the empty void I had just filled.
Skip forward to this year's project to make a home office. I am reducing the width of the window so took the inner cill off last night to cut it down. I found the cill was mastic'd to the thermalite inner wall and in doing so it dislodged the entire top course of blocks leaving the plasterboard finish intact. I also then discovered why the draughts and mould were appearing. No cavity insulation and no sealing at the ends of the outer cill to window frame. In addition there are no brick ties between the courses or where they join the original window reveal - they appear to have mortared onto the painted surface only.
The picture isn't great but here are the questions:
1.For an 1850mm wide x 800mm deep section of cavity wall that only supports a UPVC window does this need to have brick ties?
2. If it does, what can I do to retrofit? (I don't mind taking down the inner course but want to avoid damaging the outer skin)
3. What would be the best insulation to fit to this cavity
Would expanding foam be suitable for the cavity and act as a way of securing the two skins or would this generate a new damp problem?
4. Shouldn't the top course of thermalite blocks actually close the cavity rather than have the inner cill acting as the closer?
5. As the inner skin does not appear to be tied or keyed into the original wall should I rip the entire inner skin down and rebuild it as I will be wanting to hang an 800 x 600 radiator from it?
As usual any help will be much appreciated.
Thanks.
Thanks.
