- Joined
- 8 May 2017
- Messages
- 10,667
- Reaction score
- 2,872
- Country
What did you try exactly ,and what was the result ?
So last Saturday after flushing out the sentinel I did as you suggested and the flow came through on both sides at a decent speed. I filled a couple of buckets up from each pipe. I only did this on the hallway rad.What did you try exactly ,and what was the result ?
Thanks. Tried this this morning and still nothing from the hallway. All other downstairs rads are fine. I don’t understand how it can work fine for 6 days and then stop again.Close all rads by their TRV, except the rads that don't heat up,and run central heating. Do they then heat fully ? If they do, it's a balancing issue.
I turned them off using the TRV’sDo you mean you turned off ALL the other radiators?
I‘m not sure. It’s probable. is there a way to tell without visibility? The hallway rad used to be first rad to get hot downstairs after the upstairs rads.Are the problem downstairs radiators fed by pipes dropping from the floor above?
No. it’s not making any differenceClose all rads by their TRV, except the rads that don't heat up,and run central heating. Do they then heat fully ? If they do, it's a balancing issue.
If no heat at all with all other rads turned off then you probably have a severe restriction/blockage on the pipework to that radiator.No. it’s not making any difference
Thanks for replying. I really appreciate it.Have you got a hot water cylinder ?
Is there a by pass on your system pipework ?
When closing all radiators that heat normally by their TRV's ,do you also close down the towel rads and any radiators that don't have TRV's ? And in that scenario do the problem radiators still not heat up ?
You still think this is possible even though when I disconnected the rad the water was gushing out?If no heat at all with all other rads turned off then you probably have a severe restriction/blockage on the pipework to that radiator.
