Hello,
I have some tiling to be done at in my bathroom and after some advice on products to be used.
Some info:
Floor- 600x300 porcelain on 18mm WBP ply, floor isnt completely flat as a triple joist sits a bit higher in the middle but not too bad. approx 3m square to be tiled.
Walls- tiles undecided at moment but probably something cheapish, walls are a right mix mainly plaster in shower area, some ply boxwork (small area), plasterboarded wall, and a chase filled with bonding. at a complete guess about 16m square.
I contacted BAL who advised:
floor- SPF flex and mircomax 2 and GT1 add mix.
wall - SPF flex and micromax 2.
CTD have said that is somewhat overkill and Weber products would be better suited.
Is using weber for this small bathroom ok, or is the extra outlay on BAL worth it?
Any input is much appreciated.
Some info:
