Balancing rads - what and which?
18 Nov 2007
Northamptonshire
Guys,
I'm planning an attempt to balance my combi ch system and have two basic questions which will give you some idea of my level of ignorance!:
1. when I take the plastic cover of the LSV, I can see a spindle-type thing poking up ... is it that spindle I should be turning or is it the nut underneath it?
2. Which way should I turn the spindle (or nut) to open the valve?
Loosen the nut first and then turn the spindle anti clockwise to open.
Check out post no 2 in the FAQs for balancing. :D
Ok tried that ... now please excuse my utter ignorance but ...
I undid the nut a little and began turning the spindle anti-clockwise ... and, because I wasn't clear on how much to turn the spindle, I decided to take off the brass nut completely and continued happily turning the spindle for ages until it wouldn't turn any more ... then I realised I couldn't get the brass nut back on ... :oops:
so I turned the spindle clockwise again until I could get the nut back on ... then I turned the ch back on and ... water came out from the 'nut' ... so I tightened it up until the water stopped ...
so, I was wondering ... just how many things had I got wrong with the procedure!
:oops: :oops:
