Is that the cabinet in the picture? If so then i would of thort a grundfos would fit there! As i say never had any problems with the grundys and it is a bigger bore pump which i would of thort should sort your problem, ive used them on 5-6 bedroom houses with about 12 zones and once air is out the system away they go, as you say though if its running quiet then chances are you wont have air in the system! Never been a big fan of wilo pumps, may not be the problem but thats what my money is on
Yeah that’s the cabinet. Hmmmm... I’ll nip out to a local shop and give it a try then. Shut off the flow and return, close the flows on each loop and remove the actuators yeah? Once installed, you’d open the flow and open the bottom drain off to push any remaining air out of the manifold yeah?
Which grundfos model would you suggest? I’ll nip to a local merchant and get one now.
