Hi all - the house I've just moved into has a small first floor balcony. Its floor is made of decking.
However, I noticed over the past couple of days as it's raining, the water is coming through the underside of balcony (which has down-lighters in it!!). I took up a couple of the decking panels and it seems that whoever built it didn't think to attempt to make the floor waterproof - the have basically screwed decking straight onto the joists that make the balcony.
I was thinking of buying some roof felt; taking up all of the decking and nailing the roof felt to joints to waterproof it, then laying the decking back over.
However, I'm not sure on 3 things:
- Is this the best solution?
- How would I join the felt to the house wall to ensure water doesn't seep through? Could I seal the gap with roofing mastic?
- One concern is that water will gather on the felt and if it's covered with decking, then it would be able to evaporate away so potentially I end up with decking sitting in a pool of water - is this a valid concern?
I'd appreciate any views on this.
Many thanks.
Many thanks.
