Hi, just read the sticky 'basic guide' but want to double check
I have done several small tiling jobs with complete success. Last was WC in marble, 3m floor 7mwall. To prepare the floor I just used adhesive and screw to secure 6mm hardibacker as the deflection was very minimal. All has been fine.
Now I want to do my kitchen 6.5x4.5m, so different proposition. Got suspended timber floor with old pine T+G boards. I have to take boards up anyway as fitting UFH. To minimise height can I get away replacing old boards with 22mm Ply with Hardibacker (adhesive and screw), or just straight onto 25mm ply?
Are noggins needed for the full length of each board joint, as each will have to be cut for UFH pipes?
Also can you confirm the type of adhesive that should be used under Hardibacker (unmodified meaning...)...
Tiles will be 400x400x12 limestone
Measure twice, cut once
