basin waste under floor joists
6 Feb 2010
Blackpool
If.runing a basin waste pipe in a house.in the ceiling void clipped to the joist. Would noise be a problem as the room.below is the kitchen dinner
No - but if you're concerned then wrap the waste pipe in mineral wool
Yes, as long as you're going between the joists, and not trying to cut through them.
Correct lay out is bath then basin at end of bath. So waste could run under bath but would then need a small boxing after the bath to the basin. So guessing under the floor would be neater?
Under floor would be neater, as mentioned though, run the pipe parallel with joists, do not notch and run 40mm pipe across the joists. Recommend you use an anti vac or waterless trap on the basin to avoid the bath pulling on the trap.
Ah ok, was just the wording, If you are creating separate runs then of course that's the ideal.
