Basketball Rim above garage - unusual placement
12 Jan 2025
Switzerland
Hello,
We will add a basketball backboard/rim above the garage. Its high quality and heavy (not quite 100 pounds altogether)...
Basketball Hoop Net
Here's a detail of the wall extender. The 4-bolt side normally attaches directly to the wall ...
However, the front wall of the garage is not high enough for the rim to be at standard height (3m).
So, we plan to create a vertical extension of the wall, from the back side (above the waterproofed level)...
Concrete Grey Silver Cement
... using hollow steel rectangular tubing (2.5 cm x 2.5 cm).
Building material
Two tubes will be attached horizontally and directly to the wall and two vertical tubes will attach on top of the horizontal ones and extend 25 cm above the wall.
The wall extender, that came with the backboard, will attach to the vertical tubes.
Diagram Triangle
Would it be better to bolt all the way through the 12 cm wall? Or could I get away with Fischer FBN 8/50 bolts?
Household hardware Screw
I might even add some vertical reinforcement with these L-shaped steel corners. Don't want the backboard bending in the wind, do we?
Plastic Label
If nobody dunks on this, can we build it to last a few years?
Thanks for any advice to ensure this is doable and solid!
Hello,
Basketball Hoop Net
Building material
Diagram Triangle
Plastic Label
The top horizontal rail fixings will fail. Then the bottom rail fixings will fail.
Put a post in the ground.
Hello,
Thanks for your reply.
Why will the rail fixings fail? They are rated to support up to 600kg.
Otherwise, we could bolt all the way through the wall. Would that fail too?
Best regards
I don't know. Its a prefabricated garage and I will check with the manufacturer. If it is reinforced concrete, would your confidence in this project go up?
It looks like reinforced concrete..if it were brick they would loosen off through time.
You are going to be fetching the ball from the roof if the backboard is above the top of garage.
Well, its definitely not brick.
We will throw up an occassional airball, but it will be hard to entirely miss the backboard! And if it happens, the punishment is to go fetch!
