My bathroom, for sometime now the cold water tap the handle is very stiff and tight to turn and so very little cold water coming through the tap. So the first thing I did last week was to remove the cap from the top and there was a screw on top. I removed the screw but unfortunately the tap won't come off. I tried even with some force the tap will not come off. So there was three questions that I had...
1. The cold tap handle not coming off despite the screw removed, what may be the reason for this? I am wondering whether there could be limescale underneath or maybe I am doing something wrong?
2. For something like this where the cold water tap the handle is very stiff and tight to turn, what might be the cause? I read online but I couldn't quite understand with some suggesting applying some silicone grease between the two metal plates underneath may do the trick. I couldn't find any rubber washer so not sure whether that is the problem but the handle hasn't come off the tap yet. The bit underneath does turn but won't come off until the tap is removed. I have attached some pictures.
3. Can this issue be fixed without removing the side bath panel and needing access underneath the bath tub?
Many thanks.
Colin
Many thanks.
Colin
