Bath frame procedure
4 Aug 2006
Lancashire
Hi
Can anyone help me with this?
I have a bath and frame/legs and can't figure out in which order to install the bath.
The materials for the bath frame consist of the following:-
2 steel rods which attach to the bottom of the bath
4 feet which screw to the floor
4 steel threaded bars which screw to the feet and held in place with nuts at one end and into 4 plastic locking blocks within the 2 steel rods at the other end.
4 clips which screw to the wall and clip to underside of bath edge
My problem is working out the sequence in which all these things come together. can anyone help? Sorry I have no photos and the place where I bought the bath are just salesmen (clueless) and there where no instructions in any boxes of the frames.
Ok LearnerPlumber but do you have to slide the bath onto the locking blocks which will be sticking up in the air at the top of the feet?
Either you have a bath with very sexy legs or you are making it sound complicated when it isn't.
You assemble your legs on your bath and you l brackets on your bath plonk it down, level it with the two locking nuts drill and plug for l brackets lift bath away silicone down side and back, plonk it back, recheck level, screw feet to floor screw l brackets, fill in again with silicone for good measure go away until tomorrow.
Paul Barker you didn't really tell me anything there, read through your comment again ................... Doesn't make sense? :?:
If you cant work out how to put the legs on the bath you should call a plumber as putting the bath taps on is a far harder procedure. :roll:
