I’m looking to replace a cracked overflow pipe on my bath.
The existing pipe is “flexible” in the middle with
Straight ends of a diameter of 25mm.
I can’t find a coupler (compression joint) that will connect to the thread
on the bath waste which is just a bit smaller than a “standard” 32mm compression thread.
The overflow outlet pipe is ribbed (slightly narrower)
Allowing a “push fit” directly to the 25mm pipe.
Nothing modern seems to fit
Any ideas?
Any ideas?
