Bath panel too short
16 Jul 2009
Hull
What can be done if a bath is set 30mm too high for a normal bath panel. Guessing maybe stick something to the bottom of the panel?
a 40mm strip of white cellular plastic trim from a roofline supplier- cheap as chips.
Or get matching skirting board.
As above if the bath is an old fixture but if this is new work you can simply wind down the legs or adjust any blocking to drop the 30mm needed.
AAMOI: using a strip of plastic trim (as suggested above) you could glue it to the top of the panel and hide most of it under the bath tub rim.
