Bath Panel
12 Mar 2007
Can someone tell me how to remove a bath panel? There is nothing I can latch on to. It matches the floor and there is a transaparent sealant all around it. It does move slightly but I can't work out how to get it out.
Texto
hi had a lot of these just cut the sealer all round and scrape it clear of the front of the panel i use an old knife and bend it about 1" from the end then you can feed it under the panel and it should pull out can sometimes need a lot of pulling but move the knife allong as you pull it a bit at a time
PS if the knife does not want to bend try heating it up then it will
best of luck
Thanks for your reply. I've tried it with screw drivers. Do I need to pull it out from the top of bath panel or should I squeeze something between the floor and panel to pull it?
It is a tiled panel.
well tiled panels are a pain in the buttt becauase most are just boarded up with no regard for removal i would try pulling it from the bottom
failing that i would try drilling through the tile only on the joint at a few inches in from each end the put in a screw or better a hook that will give you something to pull with
Thank you for your help. Once I sliced off the silicone gel all around with a knife, I use two screw drivers and pushed it out. Pretty heavy stuff.
Ta
Texto
