bath plug problem
20 Mar 2009
is it wise to fix in plughole by using silicone glue coz i cant screw plughole to wast pipe :?
Wastes (plugholes) are not usually fitted directly to waste pipes, there should be a trap (u-bend) with the appropriate fitments on each end.
Perhaps you'd like to provide more detail about what you are trying to do?
the screw inside the strainer fixes to wast pipe to hold strainer in place
cant fit nut to screw not enough room from bottom of bath to floor so is there any other way to fix it to bath (strainer)
Get a second person to help you.
Hold the nut on the underside of the hole in the bath and get your assistant to screw in the strainer.
How on earth are you going to attach the trap if there's not enough space to get the nut on the strainer?
