Hi, I'm looking for some advice regarding a bath/shower mixer. My daughter has just moved into a two storey house with a bath/shower mixer in the first floor bathroom which is not mixing - it's either all cold or all hot, so no mixing. The hot is gravity fed, so pressure is about 0.2 bar at the mixer; the cold is mains fed, pressure measured at 3 bar on the ground floor.
I think the lack of mixing is due to the pressure difference between hot & cold. I thought installing a pressure reducing on the cold feed should solve the problem. All the common pressure reducing valves I have seen, however, have a minimum output pressure of 1 bar, so it won't be possible to have the hot & cold perfectly balanced.
Do you think reducing the cold to 1 bar with a pressure reducing valve will work? Any other suggestions gratefully received! Many thanks. Andy
