Pressure Reducing Valves
23 May 2006
In a new bathroom installation, I am fitting a bath mixer & a thermostatic shower.
According to the instructions, both of these work best with a reasonably balanced hot & cold pressure, (which might account for the temperature problems encountered with the old Aqualisa shower)
I have 7 bar cold & 2.5 bar hot pressure at the shower point.
Water is heated via a multi point hot water boiler, & cold is mains fed.
I am thinking of installing a Pressure Reducing Valve immediately after the main stop tap to try and reduce the difference in pressures.
Has anyone any experience of these valves?
9 Jan 2006
Worcestershire
i`m looking at the same problem with a similar set up and pressures, if you find a solution to this please drop me an email at [email protected]
I cant seem to find too much info on here. Valves seem to vary quite a lot in price.
you also have option of pressure equalising valve at the shower itself.
