    Dismiss Notice
Bath Shower Mixer Problem With Hot Tap
Discussion in 'Plumbing and Central Heating' started by verachion, 16 Mar 2015.
  1. verachion
    verachion
    16 Oct 2009
    24
    Thanks Received:
    Hampshire
    Country:
    Hello,
    I have a problem that I would like some advice with please if poss. I have a traditional bath shower mixer that I purchased from a company called Victoria Plumb they are internet based. The hot tap does not seem to be working properly. The reason I say this is because when I turn on the hot tap there is not so much water as the cold tap and when I turn the hot tap on full the water stops running? can anyone advise me what I should do? is it a case of buying new taps? I have 3 year old triplets so I need to do something smartish as at the moment we are having to use the shower, which is not too great as you can imagine, what with little wet monkeys flooding the bathroom.
    Thanks for any help in advance .
  2. TeaTime
    TeaTime
    21 Jan 2015
    362
    Thanks Received:
    47
    Kent
    Country:
    Has this recently happened with and has the tap/shower mixer been in for a while?
    What is the model of the tap, if you know it?
    • Thanks Thanks x 1
  3. Sponsored Links
  4. verachion
    verachion
    16 Oct 2009
    24
    Thanks Received:
    Hampshire
    Country:
    No it hasn't recently just happened, it seems to be getting progressively worst. First of all the level that turns the bath to shower broke and now this :( The tap has been in since 2012.
    The model of the tap is HAMPSHIRE BATH SHOWER MIXER
  5. TeaTime
    TeaTime
    21 Jan 2015
    362
    Thanks Received:
    47
    Kent
    Country:
    Quick question, have you got service valves underneath the bath, supplying the hot & cold feeds?
    Check the hot is fully open.
    Washer may have perished in the tap and stuck down.
    You could also have an airlock in the hot pipework.
    If the lever that switches from shower to tap is broken though, you probably should look at getting a new one.
    It's got a 10 year guarentee, if you can find your paperwork for it. get them to replace it?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
