I am pretty sure I know the problem (from reading the forums etc) but wanted some advice from those better experienced.
My bathroom is in the basement of my flat and the bath is backing up, which leads to the sink then backing up.
The layout (if this is relevant) is toilet, next to sink, next to bath.
The toilet waste pipe goes straight down through the floor, while the sink drains in to a pipe that is joined by the bath waste pipe, both then going straight down through the floor through a pipe 4 foot or so from the toilet pipe.
My symptoms are this: sometimes the toilet backs up, but not always and it does drain eventually when it does.
If I run the sink taps, sometime air bubbles out through the toilet.
If I run the bath, it backs up and then the sink finally does.
This makes me think there is a blockage after where the sink and bath pipes meet.
I have tried chemicals and then I tried the professional power plunger which shoots compressed air. None to any effect (I taped up overflows etc). I am now toying with buying one of those 6m flexible rod unblockers but was thinking (after forking out £25 for the power plunger) is it better to save my money for a plumber.
In addition, and more worrying, where the pipe from the bath and sink goes through the floor (under the bath) the hole is bigger than the pipe going into it and this hole is full of water?
Any thoughts would be massively appreciated.
