I am having issues with the drainage from my bath/shower which in turn affects the drainage from my sink.
I live in a block of flats and my bath, sink and toilet all run into the same down pipe. The bath and sink waste pipes join together prior to meeting the large bore downpipe that the toilet is also linked to.
The pipes are only newly fitted and are not blocked as this has been tested and the water does eventually run away, just not freely. If I use the shower (fitted above the bath) the water backs up in the bath and only drains away very slowly. If you then try to use the sink, whilst there is water still in the bath, the sink will not drain either. However, if you use the sink before using the bath the water drains away fine, but you can hear “glugging” noises coming from the bath.
Can someone please suggest a fix? Is it likely to be an issue with vacuums?
Many thanks in advance for your help.
M
M
